Re: M with 12v conversion-Problem finding right condensor!
Posted by Randy Bridges on August 15, 2002 at 06:55:38 from (152.163.213.61):
In Reply to: M with 12v conversion-Problem finding right condensor! posted by Ryan Free on August 14, 2002 at 22:51:45:
I have converted many tractors to 12 volt neg. ground. use a ford internal resitor coil. you don't need the cermanic resitor.the stanard condensor should work.if not i have bought condensors for newer moldels at the tractor dealer or the farm & home about 1958 and up. be sure you have the coil hooked up the right way . make sure you have 12 volts to ingnition side of coil and points and condensor to dist. side should read approx. 6 volts. Ford coil for a 12 volt car with points 1957--1970
Post A Followup
: Re: Re: M with 12v conversion-Problem finding right condensor!
