Re: 300U hydraulic questions
Posted by big fred on August 15, 2002 at 10:22:27 from (12.13.226.98):
In Reply to: 300U hydraulic questions posted by Randy from S wis. on August 15, 2002 at 08:28:27:
The hydraulic screen is in the reservoir, and kind of hard to get to compared to some. Drain the hydraulic fluid, remove the seat, unbolt the hydraulic control valves from the reservoir, then remove the bolts holding the reservoir cover to the transmission, I think it's 12 bolts or so. The reservoir cover is fairly heavy, about 60-80 lb, and awkward to lift, so use a hoist and lift straight up, carefully, as the screen hangs below the bottom of the cover a couple inches. Do not set the cover down and expect the screen to handle the weight, it won't. If you want to add a filter, it would have to go in the return line, which isn't really very accessible on the 300U, since it is a part of the cover casting. If you put a filter in the suction side of the pump line, it would probably restrict the flow too much.
Post A Followup
: Re: Re: 300U hydraulic questions
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
