Re: Throw-out bearing and Clutch Release Sleeve
Posted by shuler, paul on August 15, 2002 at 14:22:48 from (66.119.2.82):
In Reply to: Throw-out bearing and Clutch Release Sleeve posted by Corey on August 15, 2002 at 14:06:26:
Corey I just did a Super C and about a year ago replaced one on a C and they both had a couple of cotter pins to pull and the entire thing just slipped off. I think I put the bearing up on two small blocks of wood and gave it a little tap and it came right off. Think I put the new one on the same way.Hope this is what your asking?
Post A Followup
: Re: Re: Throw-out bearing and Clutch Release Sleeve
