Re: Re: M with 12v conversion-Problem finding right condensor!
Posted by Bob on August 15, 2002 at 16:37:25 from (66.231.125.171):
In Reply to: Re: M with 12v conversion-Problem finding right condensor! posted by BB on August 14, 2002 at 23:11:53:
Condensor values are in microfarads, NOT volts. The volt parameter of a condensor would be it's breakdown voltage, which would be WELL in excess of either 6 or 12 volts. Therefore, a condensor designed for a 12 volt sytem would work for a 6 volt system, however there may be a difference in mfd. values between manufacturers. You should be able to find a small 12 volt capacitor as a replacement for a 560 or 660 or 706 gasoline tractor, or something of that vintage.
Post A Followup
: Re: Re: Re: M with 12v conversion-Problem finding right condensor!
