Re: Smoky rebuild
Posted by White smoke is Water on August 18, 2002 at 01:17:41 from (65.56.218.33):
In Reply to: Smoky rebuild posted by Mr. Mayor on August 17, 2002 at 21:21:03:
Blue smoke is oil being burned. Black smoke is excess fuel. White is water turned to steam. If you did not use factory headgasket for a 113, you may not have a good seal. Re torque headbolts and reset valves. Did you check for warped head? G.
Post A Followup
: Re: Re: Smoky rebuild
