Re: switch magneto
Posted by gene b on August 18, 2002 at 06:20:30 from (63.25.166.136):
In Reply to: switch magneto posted by John Czubas on August 18, 2002 at 06:00:47:
sounds like someone has changed your wiring around the mag will run without batterys as they make thier own yours mist have an external coil that uses the batt volts for spark you should get a owners manual as that will show the complete wiring dia
Post A Followup
: Re: Re: switch magneto
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
