Re: Putting rings in a H farmall
Posted by joe on August 18, 2002 at 19:16:05 from (66.43.207.226):
In Reply to: Putting rings in a H farmall posted by dave westlund on August 18, 2002 at 19:09:05:
all you have to do is remove head and oil pan, unbolt rod bearing caps, and the pistons will slide right out the top of the motor. I believe the only reason a person would need to pull the motor is to replace the front and rear oil seals, but if you are not leaking oil, that is not a concern. If I were you, I would also slap a new set of rod bearings in it while you're at it.
Post A Followup
: Re: Re: Putting rings in a H farmall
