Re: Farmall A spark plugs
Posted by Phlogiston on August 18, 2002 at 20:42:42 from (67.242.31.59):
In Reply to: Farmall A spark plugs posted by John Martin on August 18, 2002 at 19:54:29:
D-21s are the next hotter plug in the series. This helps with fouling, but that does not seem to be your problem. I just went through a similar situation with my Cub and I replaced all the things you said you did. It finally turned out to be the points and condenser. I would also check the timing.
Phlogiston
Post A Followup
: Re: Re: Farmall A spark plugs
