Re: H Pulley gearbox lube
Posted by The Red on August 19, 2002 at 03:47:00 from (12.84.238.222):
In Reply to: H Pulley gearbox lube posted by Chris/Mo on August 18, 2002 at 20:03:23:
Chris the H tranny holds 6 gallons of 90 weight. It slings it up into the belt pulley assembly. If you carefully look at the belt pulley assembly, the portion that holds the pulley itself is lower than the rest of the unit. It will hold about a quart of oil. When I change 90W, I unbolt the belt pulley facing and tap it out 1/4". You will get a quart of oil and WATER. After I rebolt the facing, I save about 1 quart of the new 90W and fill in the belt pulley filler hole so it has oil from the beginning. The excess just dribbles down into the transmission. Don't forget the forward drain plug on the transmission. It is just below the plate between it and the liftall.
Post A Followup
: Re: Re: H Pulley gearbox lube
