Re: 460 Clutch TA
Posted by RPM on August 19, 2002 at 09:47:08 from (63.110.182.225):
In Reply to: 460 Clutch TA posted by George Kelley on August 19, 2002 at 04:36:11:
Its not a formidable job if you are no hurry and this kind of job doesnt scare you, they are not that complicated compared to a 706 or newer tractor, SMTA/300/350/400/450/460/560 similar design, clutch is easy, you will have to split TA center housing away from engine and rear trans housing, it has a mechanical ramp w/rollers, this is rebuilt by most clutch/TA rebuilders and seem to work just as good as new and much cheaper, also will need the carrier and usual seals + bearings.
Post A Followup
: Re: Re: 460 Clutch TA
