Re: Carb rebuild kits
Posted by BIG JOHN on August 19, 2002 at 18:48:50 from (205.188.192.161):
In Reply to: Carb rebuild kits posted by Scott(TN) on August 19, 2002 at 18:14:52:
Chances are that all that is wrong is that you have dirt in the float valve that isn't letting it close. A good cleaning will do the trick. The other possability is that your float has a hole in it and it has filled with gas and no longer works. Replacing the float will correct this problem. Neither is a major problem and you sure don't need to replace the carb. GOOD LUCK
Post A Followup
: Re: Re: Carb rebuild kits
