Re: Super A vs. Allis CA
Posted by big fred on August 19, 2002 at 19:21:38 from (65.219.138.102):
In Reply to: Super A vs. Allis CA posted by John on August 19, 2002 at 17:56:06:
The CA is quite a bit more powerful, probably a better tillage tractor, but harder to find parts for and well, let's face it, it ain't red. The CA can probably be found a little cheaper than a Super A, mostly due to people's greater familiarity with Farmall tractors. The CA was also available with power adjust wheels.
Post A Followup
: Re: Re: Super A vs. Allis CA
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
