Re: Anti freeze in the oil on H
Posted by Paul Shuler on August 19, 2002 at 22:04:31 from (205.188.192.23):
In Reply to: Anti freeze in the oil on H posted by Kelly C on August 19, 2002 at 20:40:35:
Hi Kelly, just had a problem sort of like yours on my tractor.On mine was draining the antifreeze and saw drops of oil in it. Drained the oil and couldn't tell if it had water or not. Pulled the head and the gasket was bad between 2 & 3. If that turns out to be your trouble be sure and run the tractor till good and hot and retorque the head bolts to around 80 lb.s.You won't belive how much they will loosen up.
Post A Followup
: Re: Re: Anti freeze in the oil on H
