Re: carb woes
Posted by farmalittle on August 20, 2002 at 06:50:17 from (209.131.235.88):
In Reply to: carb woes posted by wvhogleg on August 20, 2002 at 06:29:21:
Sounds like to me you have a couple of problems. First, you may have a hole in your old float. If a float has a hole in it, gas is able to seep in and keep the float from allowing enough gas into the carb. This would require you to choke the tractor for it to get enough gas.
Second, your sediment bowl should fill as soon as you open the valve. Sounds like you have an obstruction somewhere.
Post A Followup
: Re: Re: carb woes
