Re: carb woes
Posted by kjm on August 20, 2002 at 09:58:28 from (207.177.88.6):
In Reply to: carb woes posted by wvhogleg on August 20, 2002 at 06:29:21:
It sounds like your float is to low and won`t let gas in the bowl. Adjust the float, with the carb upside down and the bowl off the float should be level with the carb, make sure that the wire keeper that goes between the needle valve and the float is hooked up. You should be able to blow thru the gas line and see if it`s working. I know what I mean but it`s hard to tell somebody else. lol kevin
Post A Followup
: Re: Re: carb woes
