stuck lifters on a 460
Posted by Andrew on August 21, 2002 at 11:52:02 from (63.151.104.12):
Got the pistons out of the block, only one intact and two intact sleeves, no cracks in the block(yet) I need to get the lifters and cam out. They are stuck tight. cam will move a little back and forth but not rotate. can't remove the cam because the lifters are stuck. Any suggestions on how to remove them without breaking the block, heat, pounding etc?
Post A Followup
: Re: stuck lifters on a 460
