Re: Re: Super H carbs suck, compression
Posted by Carey on August 22, 2002 at 15:13:51 from (209.245.228.36):
In Reply to: Re: Super H carbs suck, compression posted by The Red on August 22, 2002 at 06:23:34:
I put the trottle in high idle then run the screw in till it starts to starve the motor then back it out a hair. Then I set the throttle in idle and set the fuel air idle screw. I then put the throttle in high idle real quik(H's arent to responsive I guess) and it puffs a smoke cloud and a loud vacum sound comes from the carb and it dies.
Post A Followup
: Re: Re: Re: Super H carbs suck, compression
