Re: exact date of 1941 M fcarmall
Posted by Farmer Bob on August 22, 2002 at 16:10:31 from (66.152.73.152):
In Reply to: exact date of 1941 M fcarmall posted by Arthur Ash on August 22, 2002 at 15:16:46:
Exact build dates are hard to find for Farmalls unless the documentation was kept when delivered to the first owner and on and on. The FBKM # is the motor number and appears that it is 8 higher than the other number you gave which was probably on the serial number plate on the left side clutch housing. Look at the major castings for a number like 5*23*K (The * looks like a slotted screw head). This part would have been cast on May 23, 1941. The first M made in '41 was serial number 25371 and nearly 5,600 were made that year. Suffix letter J in those casting dates would indicate cast date of '40. Sorry I can't be more specific as to what day your M was built.//FB
Post A Followup
: Re: Re: exact date of 1941 M fcarmall
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
