Re: Plastic Dummy Spline
Posted by Bus Driver on August 23, 2002 at 17:12:07 from (65.165.154.95):
In Reply to: Plastic Dummy Spline posted by Corey on August 23, 2002 at 15:17:55:
I have replaced clutches without an alignment tool, but prefer to use one if available. Turn one on a wood lathe. Pilot bushing diameter at the front, then step up to the diameter of the inner part of the clutch plate splines. Just a few minutes work.
Post A Followup
: Re: Re: Plastic Dummy Spline
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
