Re: 1951 M Advise Needed with Broken Starter
Posted by John (SC) on August 23, 2002 at 19:37:36 from (206.74.216.55):
In Reply to: 1951 M Advise Needed with Broken Starter posted by Farmall Don on August 23, 2002 at 17:40:53:
Taking out the pump will make it easier to get out,but if there are some behind the flywheel,you can leave them in,which like youy say I wouldnt do or split it and pull off the flywheel.
Post A Followup
: Re: Re: 1951 M Advise Needed with Broken Starter
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
