Re: H-Hydraulic System
Posted by Mr. J on August 25, 2002 at 16:21:43 from (204.184.253.248):
In Reply to: H-Hydraulic System posted by MBF-MO on August 25, 2002 at 15:07:11:
If you have a lift-all belly pump, all of the lines are pressure lines. The system is one way and each line is pressure and return. You could attach the cylinder to any of the outlets and be successful. The belt pulley doesn't have to be engaged to run the lift all.....
Good luck, hope this helps...
Jared Jeffries
Post A Followup
: Re: Re: H-Hydraulic System
