Re: Re: Super C ????
Posted by Stan(VA). on August 26, 2002 at 05:06:35 from (208.59.157.253):
In Reply to: Re: Super C ???? posted by J3nut on August 25, 2002 at 15:08:58:
I don't think that the grill would interchange without also changing out the radiator as it is an inch and a half taller on the Super C. Put the two noses side by side and you should see that the lower section (between the seam and the lowest slot cutout) is an inch and a half taller on the Super C. This hight difference continues back and you can see that extra height under the gas tank as well.
Also the clutch and brake pedals are straight on the C and curve back towards the operator on the Super C. Temp gauges and serial number breaks listed also help.
Stan(VA).
Post A Followup
: Re: Re: Re: Super C ????
