Re: Help on a 400 gas
Posted by Bob M on August 26, 2002 at 08:56:07 from (165.170.128.65):
In Reply to: Help on a 400 gas posted by Scott(TN) on August 26, 2002 at 08:15:34:
I agree with Red - it's probably a manifold leak. You might be able to verify by liberally spraying WD-40, or by holding an unlit propane torch around on the 1-2 intake manifold runner and gasket area with the motor idling. If this gets you get a few hit's on #2, the manifold/gasket is the problem.
Another possibililty however: A sitcky, slow-closing valve on #2. The valve will work normally at cranking speed (thus yielding good compression readings) yet will hang up at running speed and cause a misfire. My wife's dad has a Super H that does this until it is warmed up . Occasionally the slow closing valve will cause the pushrod to become disengage from the rocker arm, requiring removal of the rocker box to put back into place. This winter the head will have to be pulled to locate and correct the problem.
Post A Followup
: Re: Re: Help on a 400 gas
