Re: F-12 Wheels Won't fit
Posted by John (SC) on August 26, 2002 at 13:00:50 from (206.74.216.188):
In Reply to: F-12 Wheels Won't fit posted by Steve Durbin on August 26, 2002 at 07:52:35:
Did you spread the center apart or just try to slide them on there.There is a threaded hole between the bolts that you run a bolt into to spread the center open so that will slide on.
Post A Followup
: Re: Re: F-12 Wheels Won't fit
