Re: Re: Re: Property drainage, need advice
Posted by Ludwig on August 27, 2002 at 08:07:45 from (216.41.29.213):
In Reply to: Re: Re: Property drainage, need advice posted by KURT on August 27, 2002 at 07:06:17:
Yeahbut if your neighbor needed, for example, to move some hay to some cattle and had to drive through that area, even if it only happened on that one day, and even if he could go through elsewhere you've caused him to have to change his ways on his land. Thats not a very good practice.
The best thing you could have done was ask your neighbors opinion in the first place. If his plan didn't work you'd be vindicated to say "well I did what you wanted, what more can I do?" but since you didn't you need to check in now.
I definately sense there is more story here, where does the second neighbor you mentioned come into it all?
Post A Followup
: Re: Re: Re: Re: Property drainage, need advice
