Re: Re: Property drainage, need advice
Posted by Don LC on August 27, 2002 at 08:47:31 from (24.166.248.35):
In Reply to: Re: Property drainage, need advice posted by FC on August 27, 2002 at 08:18:02:
You can't drain run off water onto your neighbor.....If your driveway stops the runoff,sounds like to me he is draing his water on you......he needs to be part of fixing this problen....You took the first step and tried to help "HIM" with his run off problem,after all the co. looked over the property and gave you a building permit......IF I was your neighbor I would be working with you not against you.....I think you have more than tried to help him.....now its his turn....His builder graded his lot to drain onto your lot.....Now he has a problem...Be friendly about it,but call the county out to evaluate the problem...that way you can't blame each other...
Post A Followup
: Re: Re: Re: Property drainage, need advice
