Re: 560 farmall - 0 compression on #4
Posted by Red Baron on August 27, 2002 at 16:43:57 from (208.231.183.197):
In Reply to: 560 farmall - 0 compression on #4 posted by dvtw on August 27, 2002 at 14:22:31:
One time I had a 460 pulling tractor and had good compression on cyl 1-2 5-6 On cyl 3-4 I had zero. Found that I had a piece of head gasket about 1/2 inch wide gone between the cyl. Your problem sounds like either a hole in a piston or bad valves.
Post A Followup
: Re: Re: 560 farmall - 0 compression on #4
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
