Re: Super A Farmall govenor
Posted by ScottyNY on August 27, 2002 at 19:59:22 from (151.202.182.234):
In Reply to: Super A Farmall govenor posted by Leon Jenkins on August 27, 2002 at 18:51:42:
A couple of thoughts, Leon. It may turn out to be the governor spring, but it sounds as if something is sticking. Check your linkages from the speed control lever, all the way forward, across, and back to the carb to make sure they're free to move. I'd be especially suspicious of an old carb, the throttle bushings in particular. If they're worn badly, they could be binding. Next I'd adjust the top and bottom of the governor. The capscrew with the jam nut on top regulates the high idle. Rein it in first. If you're also having problems with the low idle, try adjusting the stop screw on the carb first. If that doesn't get you anything, try backing out the surge spring. The screw adjusting that is inside the acorn nut on the bottom of the governor. It should only be adjusted with the engine STOPPED, a quarter or half turn at a time. If it's too far in, it will keep the engine from coming back to a low idle. If none of this works, I'd strongly suggest an I&T manual or the IH Service Manual for As and Bs (particular to 113s but works just fine for the 123). The governor is not all that hard to open up and work on. Just study the drawings before you open it up, and be aware that if the governor is dry inside, you'll want to be prepared to catch the balls that will fall out of the thrust bearing! Let us know how you're making out. Scotty
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
