Re: M FARMALL DRAWBAR SUPPORT
Posted by Michael Soldan on August 28, 2002 at 16:11:14 from (216.46.130.32):
In Reply to: M FARMALL DRAWBAR SUPPORT posted by MICHAEL S on August 28, 2002 at 12:13:20:
Mike I did what Hugh suggested, went out to the garage and measured my H...the side to side measurment taken hole center to hole center is 28 1\2" and from the axle clamp to the back of the drawbar is 19 1\2. I would point out that this could vary a tiny bit depending on whether or not a draw bar has been bent out of shape. You can also raise or lower the draw bar by moving the braces ahead or back a hole. Good luck finding a draw bar. Ontario Used Tractor parts has lots of them here in southern Ontario ( 519)523-4922. Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: M FARMALL DRAWBAR SUPPORT
