Re: Should I put on turf tires?
Posted by gene b on August 29, 2002 at 04:22:28 from (63.15.134.158):
In Reply to: Should I put on turf tires? posted by David A on August 28, 2002 at 18:52:25:
go for the turf what size rims are you using measure the outside then minus 1in for the size it is important to get the right size turf remember pushing snow the blade is in front and therefore you are not running tiresw in deep snow you can make a set of chains also and you dont have to push the snow all in one push taking small cuts will get the job done also
Post A Followup
: Re: Re: Should I put on turf tires?
