Re: Replacing PTO seal on 140
Posted by Haas on August 29, 2002 at 05:55:30 from (166.72.245.104):
In Reply to: Replacing PTO seal on 140 posted by Gerald on August 28, 2002 at 19:34:18:
The seal is a press fit. You may be able to get the old one out by drilling holes in it and screwing in some self tapping or sheet metal screws and using those to pry it out. Failing that, you will have to remove the complete housing in order to pull the shaft out so that you can drive out the seal from the back side.
Post A Followup
: Re: Re: Replacing PTO seal on 140
