Re: Re: Re: Help, Oil Change reveals problem, Super C
Posted by Paul Shuler on August 29, 2002 at 09:03:59 from (152.163.189.203):
In Reply to: Re: Re: Help, Oil Change reveals problem, Super C posted by Don on August 28, 2002 at 21:56:02:
Hi Don, On your oil filter I am almost sure you have a gasket under your oil filter. If not the oil would pour out when you run it. Don't ask how I know this!In that groove your talked about it looks like metal down in the groove, but if you take a very small flat blade screw driver you'll find it's a small rubber gasket and you have to pry it out with a screw driver. My tractor had two in it where the other owner thought it had no gasket and put one on top of it.On the oil pet cock, I think you can fill it to the bottom one drips then add about a quart of oil and be about right. The hydraulic pump is up in front of the dist or magneto area of your tractor.
Post A Followup
: Re: Re: Re: Re: Help, Oil Change reveals problem, Super C
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
