Re: Help with carb adjustment on M
Posted by Don LC on August 29, 2002 at 09:11:19 from (24.166.248.35):
In Reply to: Help with carb adjustment on M posted by Bob G on August 29, 2002 at 06:37:05:
THE RED told you what the screws were....I'll tell you how to adjust them.....Close the idle adjusting screw (not the idle speed screw)gently into it's seat,by turning it to the right...back out one complete turn....Start the engine....Turn the idle speed screw in till you have a rather high idle speed...push your throttle lever all the way down.....When the engine is warmed up to operating temp. and at fast idle. turn the idle adjusting screw in slowly ,until the engine starts to slow and run rough...back it out until it starts to slow and run rough......now run it in until it runs the fastest and the smoothest.....Adjust the idle speed where you like it...(on tractors with magneto,engine idle must be set faster than battery ign.).....To adjust the high speed mixture screw,pull the hand throttle all the way back,(wide open)adjust this screw the same way as you did the idele mixture screw (fastest and the smoothest)...You may have to turn these screws a 1/4 turn later to get it just right.....TEST--- with throttle at about3/4 open lock the breakes togeather,put tractor in fourth gear....hold breaks down and slip the clutch,putting, a load on the engine,check to see if engne pulls smooth under a load.....You need to get a OPERATOR'S MANUAL......
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
