Re: f 12ignition
Posted by F14 on August 29, 2002 at 14:57:53 from (216.204.137.56):
In Reply to: f 12ignition posted by lonnie bohm on August 29, 2002 at 14:26:16:
I've got Champion W21's in my F14 (same engine) and no complaints. Some folks run into fouling problems with Champions and have reported good luck changing to the Autolite equivalent.
Can't speak to the differences between a Wico and an IH magneto, I had my IH rebuilt when I rebuilt the tractor, and it's been dandy.
Post A Followup
: Re: Re: f 12ignition
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
