Re: I bought a plow and duals, now how do I set up the hydraulic hoses?
Posted by Denny Frisk on August 30, 2002 at 08:54:45 from (12.4.181.2):
In Reply to: I bought a plow and duals, now how do I set up the hydraulic hoses? posted by Tim Malin on August 29, 2002 at 18:26:20:
Your Operator's Manual would have all the info You'd need about setting up the hyd. for Your plow. We always used to pow with just the left dual on with Our SM-TA and 450....Mostly because We'd use the tractor to disc and it was just half as much work to pull one dual off as opposed to taking both off.. DITTO for putting them back on... It did make the tractor ride & pull a little better.
Post A Followup
: Re: Re: I bought a plow and duals, now how do I set up the hydraulic hoses?
