Re: Re: Re: Re: C123 Block Boring
Posted by Stan(VA). on August 30, 2002 at 21:02:58 from (208.59.156.13):
In Reply to: Re: Re: Re: C123 Block Boring posted by gene b on August 30, 2002 at 04:44:31:
Gene,
Thanks for checking further on this for me. I've checked with a second shop, same answer. You say a dealer was turning the overbore sleeves even thinner? If the Super C was 3 1/8" bore with 3 7/16" sleeve opening, that would give 5/32" sleeve thickness; the 3 1/4" overbore set would go down to 3/32" sleeve thickness; if they turned that sleeve down farther to fit in the earlier 3 5/16" sleeve opening it would drop to a 1/32" sleeve thickness. Do you think they can really go down that far? I'm not a machinest, so if my numbers are off, please enlighten me!
Thanks,
Stan(VA).
Post A Followup
: Re: Re: Re: Re: Re: C123 Block Boring
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
