Re: Farmall A Carburetor
Posted by BIG JOHN on August 31, 2002 at 14:47:19 from (205.188.209.78):
In Reply to: Farmall A Carburetor posted by Mr. J on August 31, 2002 at 13:05:20:
Check your float to make sure that it is not binding up after you reassemble the carb. about the only way to check for this is by ear. You should be able to hear the float move when you turn the carb upside down and then again right side up. GOOD LUCK
Post A Followup
: Re: Re: Farmall A Carburetor
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
