Re: losing hydraulic fluid......
Posted by Don on August 31, 2002 at 20:54:42 from (208.11.82.199):
In Reply to: losing hydraulic fluid...... posted by mark on August 31, 2002 at 11:52:22:
Mark, I have a super c that had 8 quarts of oil in it also. After inquiring around I find out that it is supposed to be the hydraulic pump mounted below the distributor that is the culprit. I checked with a parts man and he told me it would be either an o-ring or a bushing (depending on the pump) where the line comes into the pump and is not hard to fix. I would suggest you talk to a parts man, he should be able to help you.
Post A Followup
: Re: Re: losing hydraulic fluid......
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
