MW hydraulic pump fluid
Posted by Dick Davis on September 01, 2002 at 03:36:14 from (205.188.209.78):
Trying to get all my work tractors to push the same hydraulic fluid so I won't be comingling different fluids through common cylinders. After disking with a 49 M with an M&W pump for about 2 hours the disk would no longer raise. Checked for leaks and fluid level OK. Let the tractor set during lunch worked another hour, worked OK then same problem. My question, were the M&W pumps made to use 30wt ND like the belly pumps they replace? Would a 300 RC do ok with 30wtND? Thanks Dick
Post A Followup
: Re: MW hydraulic pump fluid
