Re: ignition problems
Posted by Mr. J on September 02, 2002 at 18:54:31 from (64.200.54.165):
In Reply to: ignition problems posted by Dale(MI) on September 02, 2002 at 17:38:22:
Dale,
Sounds like you have 2 bad plugs....even new the plugs can be bad....What I would do is this...Take the plugs out and switch them around.....move #2 and #3 plugs to #1 and #4. Then restart your tractor and see if the miss has followed the plugs...That is an easy way to tell that your plugs are bad...If you need clarification, please ask and I will try to explain a little better..
More than a couple of times I've purchased new plugs and had 1 bad plug in the bunch...
Good luck, hope this helps,
Jared Jeffries
Post A Followup
: Re: Re: ignition problems
