Re: Re: Re: Re: Re: Missing H
Posted by The Red on September 03, 2002 at 14:48:05 from (12.84.243.142):
In Reply to: Re: Re: Re: Re: Missing H posted by Ben Huyge on September 03, 2002 at 13:14:26:
Ben, loosen the two bolts on the distributor base. At full throttle, advance the timing (i.e. turn counterclockwise). If the engine smooths out, then you have one or two broken springs that advance the timing. At 1,800 RPM, the distributor should be advancing roughly 35 degrees. The springs and weights are located underneath the breaker plate which holds the points and condensor.
If changing the timing at full throttle does not help, then I am thinking a manifold leak.
Post A Followup
: Re: Re: Re: Re: Re: Re: Missing H
