Re: IH 140 Gear Box Oil Level and pto seal replacement?
Posted by Gerald on September 03, 2002 at 19:11:50 from (216.118.42.140):
In Reply to: IH 140 Gear Box Oil Level and pto seal replacement? posted by Rick S on September 03, 2002 at 11:15:50:
Rick,
Just replaced the PTO seal on my 140 this past weekend. I drilled two small holes in the pto seal and screwed in sheet metal screws. I then carefully pried out the seal using a crow bar supported by wooden blocks.
I my copy of the 140 lube guide it calls for 5 qt of gear oil if you have both the PTO and Belt pulley. My 140 only has a pto and thus calls for 4 1/2 qt...Good luck....Gerald
Post A Followup
: Re: Re: IH 140 Gear Box Oil Level and pto seal replacement?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
