Re: ignition problems
Posted by Thanks! on September 04, 2002 at 11:29:15 from (198.108.62.184):
In Reply to: ignition problems posted by Dale(MI) on September 02, 2002 at 17:38:22:
Thanks for all your suggestions. I put a set of AC C87s in last night and replaced the old ignition wire between the switch and the coil. It is running great now, will pull 3-16s in 3rd gear. I am guessing it will foul these plugs out too but eventually I will find the source of the fouling.
Dale in Michigan
Post A Followup
: Re: Re: ignition problems
