Re: 73 1066 likes it's fuel
Posted by AceS on September 05, 2002 at 04:55:25 from (67.0.16.56):
In Reply to: 73 1066 likes it's fuel posted by parttime and new on September 04, 2002 at 19:15:29:
You may want to have the spacer in the delivery valve in the pump checked if it is bad you might be putting out 250 275 HP and if you have alot of slipage as you said the sapcer is a good bet. Had 1466 wiyh spacer gone on the dyno we quite at 275 and had 100 RPM to go yet. 1066 should check out at about 15 Horses per gallon.
Post A Followup
: Re: Re: 73 1066 likes it's fuel
