Re: Marine Batteries and Old Farmalls
Posted by Don LC on September 05, 2002 at 06:34:59 from (24.166.248.35):
In Reply to: Marine Batteries and Old Farmalls posted by michael Soldan on September 04, 2002 at 19:40:48:
No you don't want to use a deep cycle battery as a starting battery....the deep cycle battery designed to be run down and charged back...that is why they are used on trolling motors....The starter battery is built to produce a lot of power for a short time and be charged ,right back to full charge.......Yes two 6v batteries has more starting power than a 12v battry.....cranking amps doesent matter as long as the two 6's have as much or more than the required needed to start and handle the electrical requirements of the tractor......
Post A Followup
: Re: Re: Marine Batteries and Old Farmalls
