Re: H Electrical Problems
Posted by Bob M on September 05, 2002 at 08:21:52 from (165.170.128.68):
In Reply to: H Electrical Problems posted by Travis on September 04, 2002 at 19:02:40:
Travis - Recommend proceeding as follows: 1 - Check (then check again!) to make sure the wiring is correct. Since your H has a 4-position light switch, the tractor was orginally equipped with a cutout relay. Since it now has a voltage regulator, the wiring has to be modified slightly to accommodate the regulator. Punch below for a diagram of how it should wired up now. 2 - Make sure the regulator is solidly grounded. Run a temporary ground wired directly from the regulator mounting base to the grounded battery terminal. 3 - Repolarize the generator. Momentarily connect the BAT and ARM terminals at the regulator with the engine off. Soon as you see a spark you've successfully polarized. 4 - Start the motor and run at 1/2 throttle. Temporarily jumper the BAT and ARM terminals at the regulator. If the ammeter now indicates charge, the regulator is bad. 5 - If still no charge, temporarily connect a jumper wire between the generator "F" terminal and a good ground. If the ammeter indicates charge, once again the regulator is bad. Otherwise the problem is in the generator. Note: Since you now have a voltage regulator, the light switch no longer has any effect on the charge rate. The L and H positions are simply two "off" positions for the lights.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
