Re: Can a tractor with a mag start on its own?!
Posted by Hugh MacKay on September 07, 2002 at 03:03:07 from (216.208.58.188):
In Reply to: Can a tractor with a mag start on its own?! posted by John (SC) on September 06, 2002 at 18:43:09:
I heard a story similar to this, actually closer to what Mike is saying. This was forestry equipment with a Detroit Diesel left in neutral, as result didn't go any where. It was running when owner got to bush in morning. They shut it down only to find it wouldn't start again. Starter had stayed engaged and it tore the starter drive to bits. They also found dead short in wiring that caused starter to go.
My suspicion, on your friends H is if starter and starter drive are intact, you have foul play. I don't think a cold H engine will start from impulse on mag. A short at starter will usually not end in precise timeing with tractors start.
Post A Followup
: Re: Re: Can a tractor with a mag start on its own?!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
