Re: IH 464 questions
Posted by Big Don on September 07, 2002 at 09:04:00 from (24.101.197.208):
In Reply to: IH 464 questions posted by Bill on September 06, 2002 at 19:11:36:
Bill:
The 464 was made at Louisville plant and was classed as American made. It did however use a "skid unit" consisting of transmission and rear end shipped to Louisville from England and then had a C175 American made gas engine added. The sheet metal was all U.S. made and a Delco electrical system was used. Parts are pretty much readily available at any Case IH dealer although some of the engine parts are getting harder to find.(that series of gas engine hasn't been built since about 1978.) The basic chassis is very similar to tractors built right up until this year by Case IH. All around they are a pretty good tractor with some deluxe features such as independent pto, hydrostatic power steering, hydraulic wet disc brakes, good size hydraulic pump(12 gpm I think)One of the most common problems with that series is the park brake. It is a band type brake in the transmission and if the tractor is driven with the brake on, it will pull the lining off the band. That is a fairly expensive thing to repair.
Hope this helps.
Don
Post A Followup
: Re: Re: IH 464 questions
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
