Re: Which way
Posted by K.B. on September 07, 2002 at 14:49:14 from (209.163.43.101):
In Reply to: Which way posted by Jim K on September 06, 2002 at 19:29:19:
Here's an easy way to show your friend that it's turning over backwards: Take a careful look at the dist. cap and the way the spark plug wires are hooked up, and which way the rotor needs to turn for proper firing order. With the engine turning the correct direction, it will fire 1-3-4-2, with #1 cylinder being the one closest to the radiator. Now pop the dist. cap and rotor off and while tuning it over with the starter, make note of the direction that the shaft is turning, with the starter turning backwards, it will turn the dist. shaft in a direction that it would fire 2-4-3-1.
Post A Followup
: Re: Re: Which way
