Re: Farmall H or super H with hand clutch?
Posted by Mr. J, hope this helps. on September 07, 2002 at 15:25:23 from (64.200.54.67):
In Reply to: Farmall H or super H with hand clutch? posted by Meg White on September 07, 2002 at 12:10:55:
Meg, I've got a Heisler Hand clutch on my M. To tighten mine, there is a spring loaded pin located behind the clutch cover plate. If you pull out on the spring loaded pin, you can rotate the clutch assembly itself. You will need to rotate the clutch assembly clockwise (I think)to make your clutch tighter. You can test your hand linkage while you are adjusting it to make sure that you don't get it too tight. I turned my clutch one full turn 360 degrees to tighten it down. I needed someone else to pull the pin out with a pair of needlenose pliers while I turned the cast iron clutch web with a pry bar. What you actually will be doing it adjusting the amount of end play in your hand clutch by threading the pressure plate closer to the clutch pads. The pin that you pull out is there to keep the clutch from backing off and becoming loose. When you are done adjusting the clutch, make sure that the pin falls back into a hole to keep the clutch web from reversing. This sounds very confusing I know....If you need clarification, please ask. I hope this helps you out a little. Good Luck, Jared Jeffries
Home
| Forums
Today's Featured Article -
The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
